Mass loaded transmission line. The cabs are almost exactly 2x volume of the Model 19 cabinets The build thread is here. I measured the power I used to push them in a small space, when they were first built, and I was using about two watts. They are driven through active crossovers but the preamp volume control is barely turned.Nice cabs man is it like a band pass or folded horn
also are you using the same compression driver I am or the 511? is there a big difference sonically?
And if something really catastrophic happens all have a couple extra receivers and my Ess Amt Heils that get with it and if that fails will go to my jeep with a 250 amp alternator to optima yellow tops an alpine MRD m 1000 powering a diamond audio 15" sub in a transmission line and an alpine MRV 540 4 channel powering two pairs or morel components 6.5" mids and 1 inch silk dome tweeters with o gauge power running to a bat cap with 200 farads of capacity and an alpine CDA 9886 with the boat control rf remote
I will order electrolytic Dayton caps. Can you use a guitar head as an amp I found one for 330 locally that's a 100 watt tube unit
Heres a link to it
http://www.musiciansfriend.com/ampl...ube-guitar-amp-with-tri-mode-rectifier#review
Believe me, I have more time with gain structure on this setup than I needed to spend. I've used different combinations of dissimilar amps, some with gain controls and some without. Your assessment about the signal handling and gain is spot on, it is all a balancing act to get to the best presentation. I have another F5 to add into this system when I get the time to build it.If your amps have gains on them, you might try cutting the gains down to allow you to maximize the gain of your preamp.
Long story short, I also (actively) biamp. I was amazed at having ZERO light indicators showing any signal strength unless the system was deafening loud.
At the same time, I saw someone else (same setup with same active) who's lights were full lit but, not going into clipping. That got me to wondering and asking more questions.
I got new amps with gains on them and now with the gains turned down (I use a Crown K2 per speaker), my preamp is forced to work harder which maximizes the input gain into the active which gives a better sound to the system.
I learned it's all about gain structure.
Sorry for temporary hijack, just wanted to offer that since I've been down that road before and feel the system sounds better with the active crossover taking a stronger input signal.
GL to the OP on your endeavour!
:thmbsp:
Yes, a good film cap is the ticket and I use them even when using the active crossovers, just for the protection.Electrolytics sound, well, not-so-good to me. The original red ended caps are fine, top grade film caps. Don't throw them out. In fact, don't bother changing them until you feel like getting something better, and there are a few better ones out there now, but electrolytic ain't it! The real weak link in the Altec XO is the tiny inductors, they will saturate with enough bass and that sounds awful... Once you put enough bass in to saturate the inductors, the tweeters will pop, so that's about as far as that box goes, volume wise anyways.
I have a pair of those that have been working for 30 years as horn protection caps, and one other that the lead broke off on. They all still measure perfect.
Guitar amps generally have way too much tone control, you would have a harder time getting a flat playback, but lots of fun tweaking...
