Please recommend bypass caps for use with new 15k main caps
scottrt
Well-Known Member
So I am putting new Nichicon KG Gold 15,0000uf main caps in my AU-717, and figured I would use fresh bypass caps.
The originals bypass caps are Metalized polypropylene 2.2uf 100 volt units.
Should I just use the same type and rating, or is there something better suited these days.....
Scott T.
Not necessarily, it's just that those are good caps and that is the lowest value that they come in. I think they should work fine. I typically use a bypass cap 1/10,000th the size of the cap I am bypassing so in this case it would be a 1.5uF but if the manufacturer had a 2.2uF in there I would do that too - I am not an engineer by any means :)
