Pls help! Newbie speaker decision paralysis-- under $300 and 10" high???
rileykerne
I am just setting up my system. Ordered a U-turn Orbit Plus turntable. I bought a Pioneer SX-424 off ebay that hasn't arrived yet, so hopefully turns out okay. I got the built-in preamp for the turntable just in case. I am between powered and passive speakers. I would ideally like to get speakers with bluetooth so i can also play music from my phone as well, but it's not a dealbreaker. What IS a dealbreaker is having really large speakers right now, as I live in a studio apartment. I am interested in the Audioengine HD3s but they are a little over budget and I am worried they will be too small-- thoughts? I was looking at the Audioengine P4s but reviews sound bad. I love them aesthetically and the size is perfect-- is there something better that is close to those dimensions (9" H x 5.5" W x 6.5" D)? Also looked at the Cambridge SX-50 and could go this direction-- a little larger than I'd prefer but if this is going to be better I would consider. I'd really like to spend closer to $200 but $300 is fine (or $350 if those Audioengine HD3s sound like a good choice for me). I don't think I want to buy used just because I don't know what to look for and I don't want to have to fix anything.
TLDR: what are the best speakers I should get that are around 9" high, and $300 or less?
Realistic minimus7's. They are pretty common and in most cases a pair of good condition used ones are usually under 20 bucks. These little buggers sound pretty damn good and are almost indestructible. Size is 7" tall, 4"wide, and 4 1/4" deep.
These look interesting. Looks like there are ones with wood cabinets and metal.
I'll second the ADS L300's. I haven't heard that particular model, but do have 2 pair of larger ADS and love them.
NHT Super Zero's are also well thought of. (The original, made in the USA, not the newer made in China.) I have a pair of Super One's that I like (though not as much as the ADS) but they're 11.5" high.
Good luck and happy hunting.
Normally I'd instantly agree on the ADS L200 & L300 variants,but in this case with that specific receiver I'd hafta hold that recommendation.
That's a low power receiver and the ADS are 4ohm speakers that would do better with a bit more power than that SX-424 has.
Normally I'd also throw out a recommendation for the Canton Plus S too,but those might tax that low wpc receiver a bit too hard as well.
The Minimus7 should be ok though,those are 8ohm and a bit less demanding as SOP.
Also conisder the Optimus Pro7 & Pro7av as they are basically the same speakers,so that should help the hunt for those some.
Then you may also want to keep an eye out for a pair of Optimus Pro LX-4 (or the Pro LX-5) with the Linaeum tweeters.
Those also sound really nice for a very compact speaker.
Just some more bits of info to ponder here...
Bret P.
How about a pair of Dayton Audio B652's for $45.00 paired with their 8" sub for $90.00. All in for under $150.00. I have that same 8" sub in my sons bedroom paired with EPI 100's and it's quite musical and pumps out great bass for it's size. More than enough for a small space.
Heck, toss in a pair of speaker stands for $56.00 and you're still just over $200.00 total.
https://www.parts-express.com/dayto...h-amt-tweeter-pair--300-651#lblProductDetails
https://www.parts-express.com/dayton-audio-sub-800-8-80-watt-powered-subwoofer--300-627
https://www.parts-express.com/sanus-bf16b-foundations-16-speaker-stand-pair--240-764
I think the power rating for the Pioneer SX-424 is optimistic. And it doesn't take well to low bass load drain at all. It runs out of steam early when used with a thirsty speaker or a low ohm load. I'm not a fan of powered subs, but with the 424 I would consider it if you will be stuck with small size speakers.
What I'm saying is the 424 has a predisposed warm sound and needs an efficient speaker or the bottom will go fat and wooly in a hurry.
With only 15 watts out put on that SX-424, your going to need some speakers that have a sensitivity of 91db or better. Cerwin Vega has some AT-12 that have a twelve inch woofer at that rating and will be the cheapest purchase at that rating.
