I used the controlled power socket on my C_34 and C-29 to turn on a Mcintosh R612 power strip. You start using the sockets on the pre-amp and the contacts on the power control relay will start pitting making noise and will eventually fuse together. I have seen happen to not only me before I got the power strip that plugged directly into the wall but countless C-29, and C 30, 31,32,33,34,35,and 37 owners. Two 275's, a MC 60, witha Pioneer 750 electronic crossover with two thorens TT's and a MR-77 fused the C-29. When I went with Crown amps that required more power I got the Mcintosh power control strip. The main power came from a 20 amp wall plug, the control ac plug connected to one of the C-29's AC sockets only pulling 10 watts as I remember. It was labeled R612 Power controlled relay. It had 6 three prong 15 amp grounded AC sockets and a very short heavy heavy AC main power cord. In order for a 7200 to reach full capability at two ohms or lower it has to be plugged directly into a wall socket or one of these AC strips as It draws so much current.
Remember Pre-amp on first and off last. or Amp on last and off first, to protect your speakers.
You'll love your C-37 it was the best of the 16" wide pre-amps Mac ever made. If you get a more current preamp some day that uses a remote control with logic connections you can use a PC-4 remote controlled power box to turn off and on the 7200 and with an additional PC-4 for other additional power hungry components. A 7200 can put out close to 1500 watts across 2 ohms both channels operating simultaneously. 648 watts across 8 ohms both channels. and over 1000 watts both channels at 4 ohms. Its quite an amp. Its the first SS Mac power amp that really matched well with my woofers because of the high Damping Factor. It was designed to drive flat paneled speakers that required ridiculous amounts of power in the high frequencies where the impedance of the speakers approached 1 ohm.
