Plug In Electrolytic Capacitor Cans
jonboy55
Well-Known Member
Hopefully I have the correct forum for this question.
I have a mono block amplifier circa 1951 where the electrolytic capacitor cans plug into sockets.
Does anyone know anything about the history of this type of design and the years they were used.
Interesting design. Can't say I've seen multi-section capacitors with a plug-in socket of that style before. My R-390A military-grade shortwave receiver uses a pair of plug-in can capacitors, but both use octal tube-style bases rather than anything like what yours use. Another oddity about those is that there doesn't appear to be any sort of clamp or other method to hold them in their sockets; granted, the plug-in cans used in my R-390A receiver generally sit upside-down (the main chassis is H-shaped, with modules on both the top and bottom), so it'd stand to reason that they'd use a clamp, but I'd figure that cans like yours would have something similar to hold them in place. Hopefully, someone else can enlighten us on the how and why of these.
-Adam
I do remember seeing the same type of capacitor sockets on a very early McIntosh 50W-2 amplifier or its power supply. They were from the same time period.
Looks like the sockets have some kind of latching devices built in. I swear I've seen those somewhere.
I'm willing to bet those sockets were designed to take what was then an almost standard arrangement for off-the-shelf chassis mount cans. The triangle and square arrangement match too well.
Most Leslie tone cabinet amplifiers use those same sockets. Not Hammond, but Leslie.
Maybe go to ToneWheel General dot com and see if they have any 4 in 1 cans of 20mfd @ 450 volts. Otherwise you can just hardwire 4 individual capacitors underneath or mount a regular can capacitor using a new socket with holding clamp. Anything can be done here.
Thank you for the advice. I just tried that web site and they don't have the can I needed. AES in Arizona has the exact 4 section can with the perfect measurements (CE Manufacturing) for $35.00 and the exact 2 section can for $19.00. I'm going to check out some other sources. But first I have to test the transformers to see if they work. I don't want to spend the money on cap cans if the amp will never work. By the way, the amp was made by a company called the Electronic Workshop which was located in New York City in Greenwich Village. It's a model A-20.
Have you considered taking the old can apart and stuffing electrolytics in it? You could probably do it for a whole lot cheaper than what cans will cost you.
Some may consider this solution unorthodox, but I've read others do the same here, and actually I think its a great idea. It'll even keep the original patina consistent throughout the amp.
I have no problem in stuffing the cans but the amp only came with the 2 section can. But I can probably find the right size can but it would have different markings. Let's first see if the transformers are any good.
When I worked at Aerovox in new Bedford, ma I use to roll the caps on those. They were all different sizes etc. I t was peace work toooooo.
