PM7200 recap + reamp
DaveL
Hi,
I've a PM7200, which is 15 years old and well used, it runs hot so which doesn't help interms of aging components, so I figured I'd share my experiences to help anyone modding theirs.
So I started off cleaning out years of dust that accumulated in the heatsinks.
I decided to upgrade all the dielectric caps to new caps, I upgraded all signal path elna's to elna silmic II's.
I thought it would be a good idea to upgrade dc line decoupling caps to nichicon PW's and high temp panasonics caps since this amp runs hot....., I figured all these were doing was making sure no ac ripple/noise reached the amplifying circuitry so I ignored the fact that the original caps there were all elnas (infact almost every single dielectric cap in this amp is an elna ! ).
Ooops, seriously bad idea !!, the sound was completely closed, almost muffled, and didn't improve with been run for a few days. So I put elna silmic II's into these locations and put back in the massive original 15000uF marantz labelled psu caps, and happy days, the amp was back to its nice smooth sound after a day or so of running, these elna silmic II caps do genuinely require burn-in before sounding good. So I've put all this down as a learning experience. I had read beforehand about the silmic burn-in time but hadn't really believed it until I experienced it. .
I left the short circuit protection board using the new high temperature tolerant caps as this is awell known problem area of the amp where caps blow due to aging/heat.
After all that effort, the amps sounded similar but more open, lively with better base then it had previously.
I replaced the biasing pots with new trimmer pots, the old original ones were abit troublesome in that a tiny amount of turning had a big effect, the new pots make it easier to get good bias values,
After about 4 months, I decided to have a look at the opamps, it uses 2x NJM2114D dual opamp, one for the volume and another for the phono input, and 3x NJM2068D dual op-amps for the tone control.
I decided to replace all except the phono opamps with opa2134pa's, I used sockets so I could easily swap them out for other opamps if I wanted to.
Noise characteristics were not changed in the amp/speakers by doing this. This surprisingly made a more profound effect on the amp then changing the caps did. The amp sound more live , more musical. I had been concerned that these new j-fet opamps were different beasts compared to the original bjt opamps, I don't hear any bad effects due to this, so the opa2134's are staying in.
Since I'm in Europe, I reduced the capacitance of the audio inputs as they're higher then the US model. The higher values are supposed to help reduce electrical noise/interference, but in reality all they seem to do is affect the sound in a bad way, especially on the phono input which is wayyyy to high.
If anyone has an other opamps suggestions or other improvement mods, it would be appreciated.
So I hope this will all be of use to someone who is considering upgrading their vintage PM7200, to help it last another 15 years.
Hej,
Jeg har en PM7200, som er 15 år gammel og godt brugt, den kører varm, så det hjælper ikke på ældningskomponenter, så jeg tænkte, at jeg ville dele mine erfaringer for at hjælpe alle med at modificere deres.
Så jeg startede med at rense ud af mange års støv, der ophobede sig i kølepladerne.
Jeg besluttede at opgradere alle de dielektriske hætter til nye hætter, jeg opgraderede alle elna'er til elna silmic II'er.
Jeg tænkte, at det ville være en god ide at opgradere dc line afkoblingshætter til nichicon PW'er og højtemp panasonics hætter, da denne forstærker kører varm....., jeg regnede med, at alt disse gjorde var at sørge for, at ingen AC-rippel/støj nåede forstærkeren kredsløb, så jeg ignorerede det faktum, at de originale hætter der var alle elnas (faktisk er næsten hver eneste dielektriske hætte i denne forstærker en elna!).
Ups, seriøst dårlig idé !!, lyden var helt lukket, næsten dæmpet og blev ikke bedre af at have været kørt i et par dage. Så jeg satte elna silmic II'er på disse steder og satte tilbage i de massive originale 15000uF marantz mærkede psu caps, og glade dage, forstærkeren var tilbage til sin dejlige glatte lyd efter en dags løb, det gør disse elna silmic II caps virkelig kræver indbrænding, før det lyder godt. Så jeg har lagt alt dette ned som en lærerig oplevelse. Jeg havde på forhånd læst om den silmiske indbrændingstid, men havde ikke rigtig troet på det, før jeg oplevede det. .
Jeg forlod kortslutningsbeskyttelseskortet med de nye højtemperaturtolerante hætter, da dette er et velkendt problemområde på forstærkeren, hvor hætterne blæser på grund af aldring/varme.
Efter al den indsats lød forstærkerne ens, men mere åbne, livlige med bedre base end tidligere.
Jeg udskiftede skråpotterne med nye trimmerpotter, de gamle originale var lidt besværlige ved at en lille smule drejning havde stor effekt, de nye potter gør det nemmere at få gode biasværdier,
Efter cirka 4 måneder besluttede jeg at se på opamperne, den bruger 2x NJM2114D dual opamp, en til lydstyrken og en anden til phono-indgangen og 3x NJM2068D dual op-amps til tonekontrol.
Jeg besluttede at erstatte alle undtagen phono opamps med opa2134pa's, jeg brugte sockets, så jeg nemt kunne bytte dem ud med andre opamps, hvis jeg ville.
Støjegenskaberne blev ikke ændret i forstærkeren/højttalerne ved at gøre dette. Dette gjorde overraskende nok en mere dybtgående effekt på forstærkeren end at skifte hætterne. Forstærkeren lyder mere live, mere musikalsk. Jeg havde været bekymret for, at disse nye j-fet opamps var forskellige bæster sammenlignet med de originale bjt opamps, jeg hører ingen dårlige effekter på grund af dette, så opa2134'erne bliver inde.
Da jeg er i Europa, reducerede jeg kapacitansen af lydindgangene, da de er højere end den amerikanske model. De højere værdier formodes at hjælpe med at reducere elektrisk støj/interferens, men i virkeligheden er alt, hvad de synes at gøre, at påvirke lyden på en dårlig måde, især på phono-indgangen, som er wayyyy til høj.
Hvis nogen har andre opamps-forslag eller andre forbedringsmods, ville det blive værdsat.
Så jeg håber, at dette alt sammen vil være til nytte for nogen, der overvejer at opgradere deres vintage PM7200, for at hjælpe den med at holde 15 år mere.
Thank you - that answer was very helpful! Greetings from Denmark
