Gary Mattis
I'm recapping an old Whirlitzer Organ amplifier and power supply. The power supply has two gigantic 4000 Mfd @ 25 WV caps. I am assuming that the red paint on the terminals is for negative sence the ground lug goes to chassis (see pic -yellow wires), please correct me if I am wrong ? , This thing has a 6 inch 4 plate Selinium Rectifier that I do not want going up in my face because I hooked the two 4000 uf caps up backwards. As you can see they are in parellel making it 8000 uf at 25 WV.
