OK, I just used the meter to check the voltage between front plate and wall ground at different orientation for the pioneer SX-838 receiver and pioneer SX-750 receiver. The meter is Fluke 117. When I turned the meter setting at AV voltage, I got all random numbers like 0.2V, 1.5V, OL, or 20V all over the place for SX-750, and no difference between different orientations, all randoms numbers by touching the front panel at different place. When I check the Pioneer SX-838, I got 0.2V, 0.75V or 1.5V, also random without a definite pattern, and no significant difference between different orientation. So I suspicious what I test is just ghost voltage.
Then I switched to DC voltage, I got <0.01V for both receivers. Then I tried the Auto-V setting which usually could avoid ghost voltage reading, the result is either 0 or 0.1 V DC that randomly switch between this two number without a definite pattern for both receivers regardless of orientation.
I couldn't feel the fuzz on any receiver that I have owned. I understand what you have said and make sense to me, but just couldn't test the difference in real life.
