Many Carver amps are NOT common ground! In other words, the negative speaker terminal of at least one channel in these amps, is "hot".
It is IMPOSSIBLE to use a non-common-ground amp with a Polk SDA speaker- as they RELY on the common grounding as part of the circuit architecture of the SDA system. Using such speakers on a non-common-grounded amp, can result in wonky sound at the best, and damaged amps and/or speakers at the worst!
For ANY amp to be used on a Polk SDA speaker system- it is IMPERATIVE that the amp be verified to be common ground. Unfortunately, this also excludes many other very good amps- for example, many Audio Research amps also do NOT have a common ground- the negative speaker terminal is NOT grounded, as it's part of the balanced cathode feedback mechanism used on the output tubes. They also won't work with SDAs...
BTW: I am also in the camp, that finds the Monitor 7 to be the best of the Monitor series. It's the best combination of bass extension and coherence of the bunch. The smaller ones don't have the bass extension, and the larger Monitor 10 is nowhere near as coherent as the 7, due to the dispersion and off-axis timing issues inherent with the side-by-side midbass drivers in that model.
Now- I do remember someone, who had a water damaged pair of Monitor 10s- and decided to build a pair of custom cabinets with the drivers out of them. He built them as a taller, skinnier tower, with the midbass drivers in a MTM arrangement over the passive radiator (6", tweeter, 6", passive, in that order from top to bottom). Those sounded MARKEDLY better than stock Monitor 10s, in terms of soundstage and imaging.
Regards,
Gordon.
