Polk Rt600i Problem
Thanks, I'm not positive how to completely remove a crossover to swap or test them but I'm sure I can figure it out. I'm mot challenging your suggestion but I'm just curious how swapping the crossovers could make a difference?
Because I'm not convinced the crossover is the problem. Swapping them will tell you/us more.
Resistors:
3 ohm/5 watt
3.3 ohm/5 watt
Capacitors:
9uF 100 volt - yellow mylar/high pass
27uF 50 volt - blue electrolytic/shunt
Two inductors, no idea of their values. The long black covered one is for the driver. The other is for the tweeter.
