jmitchnh
I recently acquired a pair of very mint Polk Audio SDA-1Cs. The detail, accuracy and clarity of these speakers are amazing and are unlike anything I’ve ever heard before.
From what I’ve read, all of the four 6.5” drivers per cabinet are used when the interconnect cable is attached to create the “SDA” effect, and only two when it is not attached. True?
Since my listening room is not large enough to enable me to set these up correctly to gain the full SDA effect and more than likely I’ll never use the interconnect cable, I’m wondering if it would be wise to re-wire the crossovers to allow all four drivers to operate with out the cable?
From what I’ve read, some SDA owners have done this mod with excellent results. Has anyone else tried this mod and if so, how did it work out and are there instructions for this mod anywhere on the web?
Thanks in advance for your help!
