You can do that or you could use a crimp on type pin connector (this fits in the hole nicely) attached to a piece of speaker wire. Yes the blade is only there to stabilize the pin.So, can I just buy an rca cable to use as the audio interconnect? Does the "blade" serve a function other than stabilizing the pin?
Thanks again ...
Thanks again ...
Carl, his are pin/blade. So yes, what motostereo said is absolutely correct. Every CRS I've ever seen has been blade/blade, so yeah an RCA plug would most definately not work. The newer CRS+, are mostly pin/blade. I have seen early + models with blade/blade though.
