Xoaphexox,
You are seriously underpowering the speakers, so any impression so far has little merit. So you know, they love high current amps. Removing the polyswitches and replacing them with .5 ohm resistors is highly recommended, but only if you have the proper amp to drive them with.
Despite what you may think, that short distance on the one side is a major problem.
Despite what someone else wrote, using the SDA's without the cable does not result in all the drivers working full range. With the cable removed the SDA drivers are only producing sound below 100Hz.
The tweeters are designed as a progressive point source. Therefore, one tweeter will sound louder than the other 3. So, what you are hearing is normal.
When I move the balance the whole way right I hear only slightly the surround effect in the left channel. With the same volume level on the amplifier and the balance now moved to the left, I hear the surround effect in the right speaker MUCH louder.
With the balance all the way to the right, the left channel SDA drivers should produce very little sound and vice versa. From what you say above, I would say you have an issue with the right speaker. That is, it seems as though the stereo drivers are playing when they shouldn't be.
John in MA, they are the "BEST SPEAKER EVER MADE ON EARTH DAMNIT!", you just don't have the room.
