Poly Coned Woofer AMT3's
automojo
OurBandCouldBeYourLife
In my experience, exactly want you don't want to do with your AMT3's-add a cheap set of slow-bloated poly cone woofers. Jamack should be ashamed!!:thmbsp:
They do look nice however, nice cabs and grills.
Anyone guess, but I would imagine these integrate very poorly with the rest of the speaker.
I have finally found the near perfect modern combination for the AMT3's-and will hopefully be posting soon-with pics (new camera needed first). Yes-paper cones.
You have to be willing to rebuild the crossover -add some structural bracing, addition internal (foam) damping material, and cut some new port holes-but the results so far are stunning with a half rigged mule crossover, and half finished cabs. The performance level over the stock is up 1/2 to 2 notches-which IMHO firmly puts them in the upper high end category. I have to say I was amazed myself at the transformation. I have to admit-I stumbled on the right combination-with some help from a few other AMT3 Aker's addicts.
The highs, mids and mid bass of the stock units where always well above average and better then most speakers I have heard period. But the lower mid-bass, and low bass, while nice and quick, and great at low-mid volumes-couldn't really keep up at higher volumes, and certain types of music, and would lead to compression. This is now completely gone with the Super's. The bass hasn't lost any of it's speed, just gained authority and depth. The bass has cleaned up considerably, yet hasn't lost the fullness of paper cone bass.
The potential of the stock AMT3's clearly is audible-finding the right combination to move them forward had been difficult-unless of course you are a cabinet maker etc. The physical layout, construction, internal volume are the main constraints to using modern drivers in the stock layout-just like any other speaker. It's just not as easy as dropping in a new drivers with similar specs-without physical modifications. Especially when dealing with a fairly complicated 3 way speaker, and the Great Heil on top of that.
If you aren't willing to go through the paces-stick with the stock woofers-or find a pair of stock woofers, as they are really hard to beat with the stock cabs and porting. Although I still think the stock woofers need more porting, IMHO of course.
Just don't put poly cones in there!!:sigh:
http://www.ebay.com/itm/ESS-AMT3-Ro...pt=Vintage_Electronics_R2&hash=item231c51ae33
