AvFan
My system sits in front of a bay window and one issue I had resigned myself to was that there are likely reflections from the rear of the speakers off the windows and blinds. However, I figured that treating first reflection points with absorption between the speaker and the listening position was far more important and enough.
Quite often folks put absorption, diffusion or a combination of both behind the speakers to address those reflection points. It is also pretty common to also place diffusion between the speakers. So, a no-cost approach was to twist the individual slats of the three sets of blinds to create a poor man's diffusion:
They are far from the common mathematically based diffusion panels but I have been quite surprised and pleased that the imaging of my system has noticeably improved. I have put some 1" OC703 between the windows and the blinds directly behind the speakers and I believe that also had a positive effect but not nearly as significant as twisting the blinds.
Lessons learned? First, rear wall reflections absolutely can smear the sound so it is important to address them if possible. And second, acoustic treatment doesn't need to be ideal to have a noticeable and positive impact.
