Poor mans hdmi cable ? Vs high end?
ultumax
I was lookin at monoprice what’s different between gps ? 10.2 and 18gbs , why are there cables so thin gauge ? 32-28awg how do these poor mans cables like what I will buy?
What do flagship or even high to mid range cables look like and perform ?
Any affordable quality ones !
Dedication to hdmi !!
And what specific cables do you prefer?
You need the 18gbs if you have a 4K tv with HDR so there is definitely a difference between the 12 and 18 . Now as far as cable thickness etc etc I wouldn’t put much stake in that , you just want a good shielded cable .
Also some of the really cheap cables won’t be compatible with HDCP 2.2 and can’t pass the data needed to push that therefore a solid 18gbps hdmi cable is highly recommended, doesn’t have to be crazy expensive but definitely don’t want crazy cheap either .
These are really good meet all the standards and won’t break the bank I use them with my LG 65C8 Oled tv and oppo udp-203 and they work excellent.
4K Ultra HD HDMI Cable 9 Feet by MINC - High Speed HDMI 2.0 Supports 4K 60hz 4 4 4 HDR, Deep Color, 1080p 240hz, 3D 120hz, HDCP 2.2 and ARC - 26AWG https://www.amazon.com/dp/B01CL9S9F0/ref=cm_sw_r_cp_api_i_47L4CbCG5CBAT
Audiofreak71
