yellowwagon
Years ago I built a small fan that ran on 120 volts to cool my NAD amp. It had a relay that was thermostat controlled to turn it on and off. When I first tried it out there was a great pop noise that came through the speakers when it turned off. It happened even when the unit was powered with an extension cord from a remote output. The amp was picking up the signal generated by the relay contacts opening over the air. It was acting like a radio receiver and amplifying the signal as if it was part of the audio it was supposed to amplify.
I added a small ceramic cap across the relay and the pop was completely eliminated.
You may have a similar situation.
This sounds like EXACTLY what is happening here! I’m going to request my HVAC guy do this to see if it cures the issue.
