Capt Odyssea
In Yamalibrium
Was thinking, if one had a ported speaker box, a fitted a sliding inner tube that could be adjusted.........
air tight, but adjusted from the outside.
The sliding portion would be external to the box volume, with a fixed port intrusion into the box volume.
One arriving at a certain determined overall length,
it could all be internalized.
However, how does the internal box volume changing once the set port length is arrived at externally change
things once put inside the box?
Make sense? Is reduction of box volume coupled with a longer internal port counter productive?
What about port diameter? same approach, reduce the port volume incrementally?
Am I off my Rock?
Current port is 4"dia x 11 1/4 internal currently. Volume of box is 3 cu ft.
Aka should the port volume (cylinder) should be subtracted from the overall volume?
Idle curiosity, to be followed by fabrication based on feedback !
Am I off my Rock?
