trek2112
I'm running a SAE 2200 with a SAE mark IB.....The indicator lights on the amp keep saying that one channel is getting more gain than the other by a decent margin. This has been happening even with source i know should be about even on both sides. It did seem to have a bit too much from one side. But, I didn't have too much time to look into it before i went off on my trip to Florida. I'll be back on Tuesday though. My dad wants to get the sine wave generator and use that to check it out a bit more. It didn't seem like too much of a difference but I'm not to sure about how accurate the LEDs on the amp are. The Sine wave generator should clear anything up. With a 8 ohm load the there was 19mv of DC at the jacks....But that was falling as it was measured. Is that number within a normal range? and aside of the power supply caps getting changed anything you guys recommend gets done for reliability. I plan on bringing this gear to college with me in the fall....
