Possible to ever get this finish fixed?
Mohawk toners are made for blending repairs like this. They are what furniture repair pros use. If it is lacquer, the aerosol should blend right in. Yes, these are dyes and are very transparent. I have used many types on guitars and antiques. I would prefer to have a test sample first, but that may not be an option.
You can get Mohawk - Behlen stuff here. Good pricing, too. Klingspor's Woodworking Shop.
www.woodworkingshop.com
They also have several retail stores in NC. I order Mohawk to the Hickory location. Which is also where I live. Were it me, I would take detailed photos or an actual speaker to the store and ask opinions. The place is a Mecca for woodworking freaks. Lots of knowledge there.
It may not ne an option, but I bet you could put down a "new" lacquer finish that blow the original out of the water. Polished to a mirror. Not a lot of skill required to create a stunning lacquer finish. Just patience and some effort. Very rewarding project.
Use Mohawk Ultra Classic Toner. The start of their product code is M100- xxxx. The last 4 numbers reference the color code and are different for each color. These are dye toners, so transparent as opposed to the pigmented toners.
Tape off the emblem first. Holding a piece of cardboard at the color change line and not quite touching the speaker apply an even light coat from the spray can (shake well), then let dry (minutes) to see how close the match is. If required apply more coats. Once you're happy with the color matching you may have to adjust the sheen using a clear touch up lacquer, which Mohawk sells.
Since the original color appears to have a brown tone I'll suggest using the Extra Dark Walnut toner, but I'm only guessing as I'm looking at your photo and not in person. A little toner can go a very long way, so don't apply a heavy coat. Spray a light coat from a distance of 12 inches or so. I suggest moving the speakers to an appropriate work area and either laid on their backs or elevated so you can get even coverage at the bottom.
This seems to be the best advice and the route I will go. Will be tackling in this in a day or two and will post pic for anybody's curiousity! THANK YOU!
