No, it is not. I don't know how you extrapolated your conclusions regarding Krell, and I don't know what you mean about free lunch. As should have been apparent from reading this thread, Krell's "under-rating" is most likely due to their interest in being able to present their amp as capable of "doubling down" as impedance is halved.
You are confusing the concept of "dynamic headroom" with the notion of "headroom".
Dynamic headroom refers to the ability of an amp to deliver power above its maximum continuous power rating for some very brief period of time. There are no standards for dynamic headroom ratings.
Headroom refers to the amount of non-cclipping power available beyond a given continuous output level. In my earlier example, which I will not repeat as it appears to have little effect on your understanding, I referred to an amp running at 1 watt of continuous output. If its maximum continuous output capability is 100 watts before clipping, you would have 99 watts of headroom (approximately 20dB).
On a related note...you referred earlier to the 30dB dynamic range of classical music. I think you are confused about this as well. The dynamic range is MUCH greater than 30dB. While some recordings of some rare pieces might have dynamic peaks 30dB greater than the "average" sound level, I think most experts would say that headroom to accommodate transient peaks of 20dB is generally more than adequate for a home audio system. Personally, I target 15-18dB at normal listening levels.
I would ask you to carefully re-read posts 114 and 118, and then my following conclusion:
If you've determined that you need a 200 watt amp to provide appropriate headroom (in your listening space, with your speakers, with the type of music you listen to and at the loudest volume you will want to listen to on an extended basis), you can buy a an amp rated at 50 watts with 6db of dynamic headroom, or an amp rated at 200 watts with no dynamic headroom. With the 50 watt amp, you will not know if the 150 watts of "dynamic power" can truly be delivered, for how long they can be delivered, and at what level of distortion they will be delivered. Simply put, you will be running that amp at its ragged edge of capability. Not so for the 200 watt amp.
