Repairing a Setton RS-660 that had new 15000 uf power supply caps installed wrong. The 2 negatives were strapped together and the two positives went to + 53vdc Pink wire and -53vdc white wire. This damaged one expensive cap. I reinstalled the original caps. I connected the receiver to a variac and slowly brought up the voltage 50 vac and the the left heat sinks to overheat almost immediately. The voltage at the caps was +/- 13vdc. The right amp board remaind cold. I disconnected the white wire at pin 3 of the left amp board and the negative and positive rail voltage came up to -/+ 35vdc. Let me meantion the customer had done the power switch triac mod but it was incorrect and blew the 7 amp fuse. So luckly it never got full 120 VAC or it would be a mess. I will assume the diodes on the power supply board are good.
I have recapped the amp, security and preamp boards previosly. I removed the left amp board and toublingshooting the components on the board. Found Q8 to be flakey and will replace Q7 everything else test ok.
One question. THe power transistors collector case have a high resistance to ground. Shouldn't there be zero resistance to ground? When I clean power transistors and reinstall i always be sure there is zero case resistance to ground. BTW, all output transistors test good.
I'm going to connect the amp board outside the unit to further test the board and redo the left heat sink Any ideas on why the Left channel is over heating?
I have read the lenghty post about the Laffetty 9090 / RS-660 and other posts. No help for this situation.
Ken
Ken
