redondo2018
Ok, below this is my main setup that all sits in one room (keeping the brands/models out because I often switch components in and out):
1: Pre-amp going into power amp, pre-amp has 2 turntables and R2R for inputs
2: Receiver with 2 turntables going into it
1 & 2 go through speaker cables to a switcher that, again through speaker cables, goes to at present one set of large Cerwin Vega speakers. Right now, the only component that is always on is the power amp (some have power on switches, some don't).
So, in all I have 8 devices that need power. When just the 1 setup power amp is on and switched to the speakers, I hear nothing coming from the speakers. However, whenever I turn either the 1 pre on, or the receiver (after I switch), I get a very low level speaker static that I can hear from say a foot away. Nothing that in anyway affects the music, but if I leave the components on, it is there.
So... lets just assume that there are no internal issues with any of the components or the speakers (I believe this to be the case), I assume then that it is either an interconnect or a power management issue or maybe the switcher or maybe it's just unavoidable lol. I use good banana plug speaker cables all of the same brand, but have a few different brands of RCA cables involved in all of this, including the stock ones that come with some of the turntables.
Right now I have some of the components plugged into one regular power strip which goes to another power strip (mainly because of cord lengths, as I have some components up high and others at floor level) that some of the other components are plugged into, and that one goes into the wall. There are obviously a LOT of cords, and I could probably do a better job of organizing them I guess... (a note here: I rent and can't do anything about the house electrical system, but I am in a separate one-family house, so not connected to anyone else, and all the power lines are underground in the neighborhood, so we rarely have any power issues).
I bought an 8-plug Furman power conditioner that I haven't opened yet (want opinions first). Should I crack that open, plug everything into that, and plug it into the wall? Should I focus on cord management?
Any thoughts appreciated!!!
