Power Hungry Speakers
Won't a 4 ohm load on a 16 ohm amp KILL the amp even with a 12 ohm resistor in series?
I have been looking for the thread titled "Why 4 ohm loads stress your amplifier" but cannot seem to find it.
The amp in question is rated for 16 ohms only when bridged mono.
But, just by nature of that, it implies that 8 ohms stereo is the minimum impedance.
16 ohms bridged = 8 ohms per channel stereo
8 ohms bridged = 4 ohms per channel stereo
4 ohms bridged = 2 ohms per channel stereo
Just repeating what the OP said in his original post.
For Magnepans to image correctly, you need to have the dog lie in a straight line between the speakers. I thought this was common knowledge...
:D
I had the speakers pointed towards friends sitting at a table. It was the only way everyone could get a decent listen.
Moving Coco between the speakers did help with imaging. Thanks for the tip.:thmbsp:
Steve
The resistor becomes part of the load. With the 12 ohm resistor in series with the 4 ohm speaker, it presents a 16 (12 + 4) ohm load to the amplifer.
But, as I understand it, the resistor is fixed resistance. The speaker impedance is not.
Am I correct?
Yes, that's correct, but the amplifier still sees the sum of the speaker impedance and the resistor's resistance regardless of any variance in the speaker's impedance value.
So, say the speaker drops to 2 ohms, you'd still have 14 ohms load on the amp which is quite likely close enough to 16 ohms. However, it's still a waste to burn up all that power across the resistor. You'd be better off just to use a lower powered amp with the speaker than burn up the excess in a resistor because the resistor also totally screws any damping factor that you'd hope to maintain.
