I don't want to steal this thread but I am interested with the same topic.
I was thinking that 2 20amp circuits would be generous. Is that not enough. I have only one in my audio room now. Heck....it might be even 15 amps.
Any validity for having these installed?:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=110-439
jc
The 1201's won't draw alot until you really step on it. The MC1.2KW's, if you can imagine sound even better & are more efficient.
taylode..... I know a little bit about this subject, being a retired electrical contractor and electrician of 30+ years.
Two dedicated 120 volt, 20 amp single phase circuits will provide the the current requirements for the equipment outlined. Keep in mind, continuous duty circuits, those used continuously for longer than two hours at a time, should not be loaded greater than 80% of the circuit breaker rating according to the National Electrical Code. For a 20 amp circuit, that would be a maximum of 16 amps. One dedicated 20 amp circuit will safely handle two MC501 amps. The second 20 amp dedicted circuit will provide enough current (remember the continuous duty rule - 80%) for the other amps, and remaining equipment since each piece is a low current load, with the exception of the plasma screen, but should still be fine with the other gear on a single circuit. The Richard Gray Power Conditioners will keep everything clean and quiet, one for each of the two circuits.
In my opinion, future power requirements will be limited using only two dedicated 20 amp circuits. Since the addition of another dedicated circuit during the construction phase is considerably easier and less expensive, I would add a third 20 amp dedicated outlet for future use. If you ever upgrade to larger amps, or more amps, etc., you will be pleased to have that third circuit available. If you use the MC1201's instead of 501's, the third circuit would be essential.
One final suggestion. It is wise to install commercial grade surge protection at your main panel as well. Clamping surges before they travel through the house wiring is a major benifit. I have two dedicated circuits for my system (wish I had installed three). Besides commercial grade surge protection at my panel, I installed Pass & Seymore hospital grade surge protection outlets at the wall. One can never have enough surge protection living in Florida.
What Surge protection at the panel are you using?
I have the Ditek Residential Surge Arrestor installed in my electrical panel. The model number is DTK-120/240SA. It is serious protection, made in Largo, Florida. In addition to my main panel, I have a sub-panel installed in my home studio. I have a Square-D surge arrestor on that panel.
Prior to installing the Ditek Surge Arrestor on my main panel, I lost a satellite receiver, a computer, and a answering machine to surges from near by lightning strikes. I have lost nothing since, and it has been over ten years.
I also use Pass & Seymore surge protection receptacles everywhere I have electronics plugged in, including the outlet for my microwave in the kitchen. I live in a high lightnig area, and when the storms roll through here it can get scary in a hurry.
One of the biggest culprits of current surge is when utility power is interupted momentarily, then returns. Every home on the electrical grid begins to consume power back immediately, and the current surges can be extremely high. That off and on power problem is tough on equipment. I solve most of that problem with uninteruptable power supply units (UPS). I have eight UPS units backing up computers, flat panel screens, stereos, and studio gear. It's cheap insurance against very costly repairs or replacements.
Thanks for good info Dan and I know what you mean living in Florida myself. . . . .
Used to live in Springhill, we had our share there as well.
Of course it took moving to Coral Springs for the house to actually get hit. :yes:
Geez Ivan......coming home to fire trucks in your yard. Man, that will tighten up the anal cavity in a hurry.
Yup, but I made a bee line for my Theater Room to check it out first.
Then I changed my underwear.![]()
:lmao:
I would have done the same thing.
I think we really need to sort out our priorities.
awprint:
