Hello, my name is Mike Allen, I just recently purchased filter capacitors and power supply board replacement capacitor kit for my Marantz 4140 amplifier. I have a couple concerns, first the minor one, of the five that are soldered to the top of the board, one of the original capacitors designated C806 is a 220 microfarad at 10 V capacitor. The replacement is 220 microfarad at 16 V. I am presuming that slight voltage change is not an issue? My biggest concern is the larger capacitor that hangs from the side of the power supply board that’s connected directly to chassis ground and the transistor on the board. The original is 100micro the new one supplied in the kit is 1000micro. Some of my research says that is a proper upgrade and other research says that will cause catastrophic failure. I’m not planning on replacing anything other than capacitors at this point. Is that 10 times stronger capacitor meant to compliment the new transistor that was in the package that replaces the original thats mounted on the heat sink? Thank you much for any guidance.
