Power supply capacitors
Willy6
AK Subscriber
Does anyone use the LKG series Nichicon capacitors for the big main power supply caps?
I was looking at some 22000uf 100v LKGs to replace the 12000uf 100v caps in my G-9700 they measure out the same as the originals 50mm dia x 100 mm length
My mistake they are 15000uf 100v LKG caps
Aluminum Electrolytic Capacitors - Radial Leaded 15000uF 100 Volts 20% Tol.
LKG2A153MKZF
Nichicon
1: $46.52
17Expected 12/21/2020
Pretty big jump in capacitance.. Inrush surge will be harder on the power switch and rectifier diodes.
Based on my discussions with a marketing guy at Nichicon those 15k caps might well come in at 13.5k, down 10% from design but well within the ±20%. Meeting the sales specification and saving Nichicon a ton of money in materials as they make the caps closer to the lower limit. This building to below rating but well within spec is for the big caps.
That to me makes the 15k cap a great choice to replace the 12s.
Yes for some apps. I used KG's. For my MX-2000 I used these " Super Through's"
https://www.partsconnexion.com/NICHICON-73620.html
I wish they were on sale when I bought them.. But.. Noooo..:D
I've used Super Throughs for main filter caps and Fine Gold's for coupling caps in a few cap coupled amps before. I used the Super Throughs in one of the two Marantz 140 power amps I have also. Even for the price you pay for them, they are still cheaper than many if the other "audio grade" caps I've seen, or used.
