matjo
Member
Dear AK friends,
A friend of mine brought a couple of NAD amplifiers (C320 and C370) with issues.
Although I am more a Sansui-Guy, I just thought I would give it a try in finding out the problem.
Tee C320 does not turn on at all, so I thought that would be the easiest one...... but I am lost already.
What I have checked so far:
No DC-voltage from Power board to mainboard.
230V AC is entering the Power Board.
On/Off switch is working (checked continuity if switched on).
230V AC is going to the Transformer (measured between Brown and Blue wire)
4 fuses seem to be OK.
But here it comes:
on all the 5 leads out of the Transformer (Gray, Red, Orange, Violet and Black (ground?)) I am measuring ca. 10,2 V AC!!! What am I doing or thinking wrong? I measured with negative on chassis and positive before and after the fuses.
And even more strange to me: with power switched off, I still read 9,78V AC on the colored leads from the Transformer to the power board???
If I understand the schematic, Gray and Orange should read 28V AC, Red and Violet should read 36,4V AC.
(see attached picture).
It might be my lack of knowledge.....am I measuring the wrong way? Or should I check somewhere else?
But here it comes:
