What is the cunsumption of your receiver ?
I put one and sometimes two thermistors in series with the AC input socket Hot side
One on the socket and one on power switch.
The "Hot" side on input socketis is the thin narrow blade of the prong, not the large or round.
In other words, this is the side where when you hold the negative probe of tyour multimeter in AC mode in your hand (To put it at your own potential), and the positive the outside of one of the RCA inputs jacks, you have less AC measuring there, the side of the narrow blade in AC wall socket is at left when the round prong is upper, and at the right, you have the large blade, the neutral, don't touch to neutral, it must conduct perfectly.
For better performances, you should always connect as it should. mark one prong and remember wheer it should be on non polarised AC plugs.
PS:
I think you can add one or two CL-90 or NTC-120D15 120 ohms 1.8 or 2A thermistors.
Also, look at the transformer itself for mecanical tightening if not correct.
