Pre Main RCA Internal Wire Chewed by Rat - PU01 Marantz 2325
richardg0n
Greetings AK,
Recapping the PU01 board on a 2325 and Found the blue shielded cable connected from PU01 to one of the RCA Pre inputs. Can someone please let me know what kind of wire I should use to replace this wire apparently chewed by a rat.
Greetings AK,
Does it have enough slack to cut, strip and solder the wires to the post. That would be my first thought. Other than that it is shielded two conductor cable, like balanced microphone cable, a piece of that would work, they make it thin too.
