Davron94
Well-Known Member
Hi All, I looked through AK search and could not find anything on this. I have a 2250B and the left channel keeps dropping out completely after about 20 minutes of playback. I think I've narrowed it down to the left channel Pre-Out jack. IIRC, this unit has some internal spring or metal clip that keeps the circuit closed between the Main In and Pre-Out jacks so that jumpers are not needed. The schematic seems to show it also. Although, someone before me installed the Marantz jumpers on the unit and I had just left them in place. The issue was occurring with the jumpers in place, but with them removed, the left channel still drops. If I insert and remove an RCA plug from the jack the channel will come back in for a while and then drop again. I disassembled the board and cleaned all the jacks thoroughly and it did not seem to help the issue. I'm not sure what this spring should look like or where it is located, but I can't see anything internally, other than if looking straight into the jacks from the outside, there seems to be a small black tab on the edge of the opening on the Main-In jacks, but there are none on the Pre-Out, whereas, according to the schematic, those are supposed to have the springs.
Anyone have experience with this and can help me move in the right direction to correct this issue, and better understand what these springs are and what they look like?
