greenflash
Hi everyone, I have a 140 Power amp without a proper preamp and I'm considering both a 250 power amp and a 3800 pre. Maybe I'd go first for a pre and then for the second power amp.
Anyway I've read in the manual that the 3800 is able to "feed" two power amps *simultaneously*
Now the seller tells me that you can connect two power amps but only one of them can be used at a time. Not sure what that means.
Anybody did try this preamp with two power amps? I don't understand how would it work with two power amps and how would I switch from one to the other. Thanks!
