I've just hooked up a NHT M6 speaker as a center speaker (not having one before) connected to an Onkyo Integra DHC-60.5 preamp and DTR-9.9 receiver (140 wpc x 7) as amp. Now I have an annoying hum coming from the added center speaker; involving the receiver/amp, with no hum when preamp is off; hum volume increasing with amp output/speaker volume.
The preamp has only 1 Center channel RCA out connector (vs. 2 for all the other preamp outs). The receiver has 2 Center channel RCA-in connectors (like all the other channels), now with one Center connector not connected to anything. Doing what I can (connecting the single preamp Center out wire to 1 of the receiver's 2 Center RCA input connectors), I get the Center channel with good fidelity other than noticeable hum. I've swapped pre-out cables, no change. Will an RCA terminator or grounding/shorting plug (75 Ohm Phono/RCA Terminator Plug?; RCA shorting plug?) set in the unused Center RCA connector fix or help this? Any other suggestions?
