lost_in_ABQ
Howdy! I've been using a Hafler P3000 amp with a Spectro Acoustics P-101 preamp, with pretty satisfactory results. However, a couple of weeks ago, I cranked it a bit louder than normal (about halfway) and PFFFT! The left channel died and smoke rose ominously from the Hafler. I pulled it apart and found the problem: one of the FETs burned up. No biggie. I ordered new ones and thought I'd sub in another amp I had, a Sonance 260. I plugged the preamp into it and fired it up. Sounded good until I put the tiniest little volume on it. The 260 started shutting down on peaks. I could hear a relay clicking, like it had detected a short. I couldn't get it loud enough to be heard properly no matter what I did. I viewed the preamp with suspicion, so I got my scope out and looked at the output. No DC, no wild voltage swings, nothing out of the ordinary. In fact, very, very quiet. But the 260 definitely doesn't like what I'm feeding it, regardless of source. I even connected a ground wire between the preamp and the amp, just to eliminate ground loop. No difference. Am I right to suspect the old preamp? Thanks for any ideas!
