I don’t know. Have never had either type of tube go bad, but my casual listening is done on solid state equipment. So the tube gear doesn’t accumulate a bunch of hours.Are the symptoms the same?
I did notice a difference in volume with an EL84 PP amp I have that came with a set of the original tubes. The signal tubes tested ok, but the power tubes were very weak. I still used those tubes for a long time though. One finely lost vacume. There was a noticable difference in volume with the new tubes though. I kept the the other three weak tubes.So, have been using the same complement of tubes in my Prologue Four amp for a couple of years now and seem to be noticing a reduction in volume recently. Would this be a case of the power or control tubes getting weak?
thanks!
Does your amp have an adjustable output bias? It may need rebiasing.So, have been using the same complement of tubes in my Prologue Four amp for a couple of years now and seem to be noticing a reduction in volume recently. Would this be a case of the power or control tubes getting weak?
thanks!
It's autobias so that's not it, I do have a spare quads of power tubes but was not sure whether to check them first or the others....Does your amp have an adjustable output bias? It may need rebiasing.
Do you have any new spare output tubes that you can try?
Do you have access to a tube tester?It's autobias so that's not it, I do have a spare quads of power tubes but was not sure whether to check them first or the others....
I recommend at least two matched pairs. A matched quad if you have the dinero.Just try the new quad of power tubes.
A PrimaLuna amp doesn't care about matched tubes. It auto-biases them individually.I recommend at least two matched pairs. A matched quad if you have the dinero.![]()
Yep, that's why I like itA PrimaLuna amp doesn't care about matched tubes. It auto-biases them individually.
Tube Compatibility — PrimaLuna USA
www.primaluna-usa.com
thanks!
They have yet to reply to me after a week or so. Will be swapping in another quad today and see what happens...I didn't care for the PrimaLuna branded tubes in my Prologue Premium so I emailed PrimaLuna and they said it would be okay to run KT-150s. They sound pretty darn good. You might try contacting PrimaLuna for their recommendations. They were pretty responsive.
