Azriel
Hello all,
I recently bought a used Debut Carbon with a Tube Box DS and am having some issues with it.
The turntable has the stock Ortofon 2M Red cartridge, and the Tube Box has stock tubes.
The sound is rather sibilant. S and T sounds are distorted and over-emphasized. The turntable is level, tracking force is at 1.75 grams (per the manual), the stylus is clean, anti-skate is at the second position.
Another issue I have is with the anti-skate. Even with the weight off, the turntable level, and the tracking set at zero (for calibration) the arm still has a strong return to the starting point, almost like the weight is on.
I'm playing records that I know are perfectly fine, but this thing makes them sound like garbage. Can a worn stylus cause this distortion? I'm the third owner, so there's no way of knowing how many hours are on it.
I used to have a Fluance turntable with an Ortofon 10M that sounded the same way from new. No amount of adjustment would take care of it. I finally had enough and sent the turntable down the stairs.
So that makes me a little leery of buying a new stylus for this Ortofon only to have the same sound. Is this what all Ortofons sound like? If so, I can't understand why these 2Ms are stock on so many new turntables.
