Pro-ject Debut II motor noise
anti-doom
Well-Known Member
My Pro-ject Debut II get motor noise after running about 30 minutes. Noise is not hearable when playing a record but it is when stop playing. It seems the motor getting noise when it is warm. Is there any way I can fix this problem? Thanks a lot.
If the noise doesn't start until it runs for 30 minutes, you probably have a bad motor. The solution in that case would be to replace it. If you're handy with a soldering iron, it's not too hard to do.
