JSA71
Hi All,
I had my 717 recapped, bias and offset adjusted and tested, and the preamp decoupling switch cleaned about 5 months ago. All has been fine until last weekend. When I turn on the amp it powers up just fine, comes out of protection in about 5 seconds and I can hear the contacts click in... all is good. Except the left channel won't play any sound unless I crank the volume knob up at which point it'll play normally, no distortion or odd sounds, sounds as amazing as it always has. I've played with the decoupling switch, switching it back and forth to see if that issue has crept back up (the right channel would cut out before the service) and it doesn't effect the issue at all. I've checked the speaker connections, source input wires, played around with all the source and tone adjustment switches, speaker selector and no issues it seems. Any ideas what it could be? From all I've read in the past I'm going to guess fuse resistors? Any help would be greatly appreciated!
Thanks In Advance
Thanks In Advance
