Leokarma
Well-Known Member
I have a 2275 and here is the problem :-
1) When play the system normally,there is no sound in right channel. Left channel is perfect. Same if I test via headphones.
2) When I hook the system via pre-out using a different power amplifier, both the channels works but the tone control on right channel (bass, mid & treble) doesn't. So if I move the tone control of both the channels all the way to the left (cut), the sound from both the channels are same. But when I start to increase bass/mid/treble, it only works on left channel. This is only if I use pre-out. Without the pre-out, see #1 above.
I guess both the above problems are independent and not related......not sure.
I tested the system thru main-in and both the channel were working - so the power amp section seems to be ok.
Can somebody help please....
