Problem with Rotel Ra 1412
vulcan
Hi
a big hello sorry my first post is a problem one
Could anyone offer advice on posible cause or where to get it fixed
The problem is with the left channel it keeps cutting out but if you wang up the volume it cuts back in well only till it quickly cuts out again
Its a Rotel RA 1412
Many Thanks
Bob
I'll give you 3 possibilities. (just my opinions) Dirty switches or potentiometers, cruddy contacts on the speaker relay, bad solder joint somewhere.
You don't say where you're located so it's hard to recommend someone to service it. :)
You could clean the switches and pots yourself. Here's a great beginners guide. Your Rotel probably needs a good switch cleaning anyway. Those are nice amps. Probably the largest, heaviest 100WPC amp I've seen. A real tank.
wow
That was a quick reply
im in Shropshire, England
Thanks for the advice and i will give the cleaning the pots and switches ago
The Rotel is a big amp with plenty of power 120 watts of course i would like one of the big classic recievers like a pioneer/sansui or the rotel 1603 i did have a1203 a long time ago when they first came out
i like the sound of the rotel amp and its not to fussy on what you pair it up with having said that the speakers have got to be able to cope with the power
Thanks for your help
Regards
Bob
By the way, if it is the really, as inductor mentions, I should have told you there's an easy check for that too. The relay is inside a clear or colored plastic box on the circuit board, about 1/2 to 3/4 inch in size. With the unit in it's "bad" running state, gently tap on the case of the relay with something non-conductive. If the sound changes dramatically, then the relay needs to be serviced or repaired.
cleaning the speaker relay contacts helped cure a bad intermittent left channel on an old receiver.. might be worth a try:scratch2:
