Well, I'm wondering if I'm just dealing with a set of inordinately "hot" KT66s here.
Been trying to re-bias a pair of Heathkit W5s, for use with reissue "Gold Lion" KT66s. The amp was just fine with a set of GE 7581s... but, with the KT66s (BTW- the amp was originally specified for KT66s), I've done the following, and STILL have slight red-plating (at the seams, very faint but there):
- Replaced the 330 ohm 7w cathode resistor with a 390 ohm 10w.
- Made a voltage divider for the voltage feeding the grid pins of the output tubes- I replaced the 100K resistor feeding the grids, with voltage divider consisting of a 180K from the source (bias balance pot) and a 270K to ground. The voltage there was around +8 volts, now it's around +4.5 volts... so I've basically biased the grids 3.5 volts MORE negative than stock, while still keeping right at 100K total parallel resistance (taking the parallel combination of the 180K and the 270K) to the grids... which is what KT66 and/or 7581 wants...
In essence... I've increased effective grid/cathode bias voltage from around -45V (with the 7581s) to around -53... and the output tubes are still not completely happy.
I did a calculation of dissipation... it's right at 27 watts cathode draw... around 109ma total current draw at idle for the pair. Which is also just within spec for the KT66 (25 watts plate plus 3 watts screen, or 27 watts total in UL mode). It just seems that this is a LOT of change necessary, to get it below that (I'm probably going to have to go to a 470 ohm resistor, which will probably make the bias more like -56V).
The amp plays fine... in fact, it's got quite a bit more "oomph" with the KT66 tubes in it. It's just that it seems like this is an AWFUL LOT of mod required to get it to bias up right.
The only other factor of possible interest, is that B+ is around 510V now on the plates... factory spec is 480V. Ostensibly, that's the difference between 110 and 120V, roughly, on the line input.
Is there any data out there, indicating that the reissue Gold Lion KT66s just "run away" when run on plate voltages higher than 500V or so? That would be odd, given that the specs for KT66s indicate tolerance for up to 550V... it would be a case of the tubes significantly deviating from specs...
I hesitate to go much further... because this type of change is making it where OTHER tubes won't work right (6L6GCs and 7581s will be far too "cold")... is it normal for KT66s to be THIS hot??
BTW: For info sake... both amps behave EXACTLY the same. So, it's very unlikely that it's problems elsewhere...
Regards,
Gordon.
Regards,
Gordon.
