Max Gardner
First time poster here.
I recently came into a pair of Klipsch KG4's. I paid $0, as some local dude was just looking to clear out a storage locker as fast as possible. I'm not sure he knew what he had on his hands to be honest. In any event, the KG4's looked super clean to my eyes, apart from a few cosmetic issues. All the drivers are intact. I did have to pop out of a few of the cones, but that worked beautifully.
The only weird thing I noticed is that the speaker terminal plate actually says Heresy II on it!
Now I know I'm dealing with KG4's because of the huge 12" woofers in the back of the speakers, so somebody must have just repurposed the terminal plate from a pair of Heresy's? No clue. Anyways, that was only sign I had that the KG4's were any less than pristine.
Anyways, after a couple months of listening, I realized that one of the speakers just wasn't putting out as much volume as the other, particularly in the low end. I swapped em out, plugged the L speaker into the R channel, and vice versa, and determined that the problem has to be the speaker, not the amp or the speaker cable. Did a blind test with a buddy to make sure I wasn't making it up, but correctly ID'd the lame speaker.
Any idea what my problem might be or how to start figuring that out?
Now I know I'm dealing with KG4's because of the huge 12" woofers in the back of the speakers, so somebody must have just repurposed the terminal plate from a pair of Heresy's? No clue. Anyways, that was only sign I had that the KG4's were any less than pristine.Anyways, after a couple months of listening, I realized that one of the speakers just wasn't putting out as much volume as the other, particularly in the low end. I swapped em out, plugged the L speaker into the R channel, and vice versa, and determined that the problem has to be the speaker, not the amp or the speaker cable. Did a blind test with a buddy to make sure I wasn't making it up, but correctly ID'd the lame speaker.
