Problems with LT5V Mitsubishi
analognut59
Problem with arm movement on my Mitsubishi LT5V vertical turntable. There is apparently no lateral movement while playing a records. After a short while lateral tracking is way off resulting skipping groves. I can move the arm laterally with the buttons, but it seems that it does not syncronize that movement while playing. Any suggestions?
All belts are brand new and all pulleys cleaned.
Bad sensor? Not sure about yours, but Mitsu was using light bulb/sensor combos to track movement back in the day, and the bulbs would burn out ...
Hello! I have the exact same problem. Have you managed to fix it? Thanks! /Jakob
