Problems With My Thorens 166 Mkll
johnkarma
I resonantly bought a Thorens Mkll with an unknown cartridge as seen in the picture. So I have two problems. The turntable produces a slight but audible hum. Is this because of the cartridge? Maybe it's not compatible with the turntable. If there are other reasons that cause this, I would like to know.
Another problem is that the anti-skate weight always drags the arm towards the right. It doesn't matter what position it's in. I know that I have the counter weight and tracking force set to their correct settings.
I appreciate the help!
Does the hum increase when you move the cartridge towards the center of the record? That I think would mean it's the cartridge that's the problem. If it doesn't change then it could be something else, like a bad belt or worn motor bearings. Have you lubed the bearings yet? I've had a bunch of different cartridges on my 165 and kind of settled on the one that hums the least. It's very faint, but still there with my Shure m97xe.
Also, with Thorens classics. The interconnects can be the issue. The factory fitted ones were only adequate at best. Might need to replace them and make sure ground points are good.
