alejandroS75
Hi guys
I have a problem with one of the channels. Sometimes it does not work, sometimes it does.
If, for example, it is working correctly and I activate some of the chromo, dolby, etc. switches. the right channel stops working. If I turn off the deck and turn it on again, then it works correctly again.
Once it is working well, if I do not touch any of the switches and use it to play, the two channels work correctly.
Can someone help me with this?
Thank you very much
Thank you very much
