Tflapjacks
Did you have to clip some of the leads off the new relay? My replacement relay has a different lead count.Noted that the relay was not a direct replacement... wired a bit different than the omron, but I worked around this.
Was consider this replacement... but the amp rating was slightly less the combined contacts.
That should do just fine.
