Wayniac
Where do you plan to use the FT-3 Teflons?
The FT-3's will be used for the input (C1), and interstage coupling, C10 and C11. The Electrocubes will be installed in locations C8 and C9.
Are the FT3s mounted with some adhesive-sticky-things? I'd be afraid that the adhesive film will fail after some time and the caps might go loose, given the somewhat higher temperatures inside the amp.
Damn. More incentive to repaint my trannies!
Nice job on hand polishing the paint.It looks like they have just the right luster to match the original paint on your other amp.It is the fine details that make a proper restoration right.What preamp.,source components and speakers will you be using those beauties with?
Dave
