PTL-Pioneer
Amazing stuff Super Noob! Fine song selection also!! Your level of work is what i aspire to
Most of the parts were in stock minus the filters... would guess somewhere around $150.What a tremendous job Super Noob! How much did all of the parts set you back?
would you happen to have a recommendation for the 22000 filter caps for an sx-950? would i still use the same 2.2 uf 450v Polypropylene Bypass Caps / ECW-FE2W225J for it as well? did you reuse the micas when you did the output transistors or did you replace them? thanks again
would these work? 661-E36D800N223MC92M
Thanks for posting all the info on your restoration. Great photos! I am considering doing some "upgrading" of what I would consider a partial restoration of my SX-850 I did a few years ago. I am curious why you replaced D8 (1S2473) on the Protection Bd. with a 1N4004 instead of what appears to be the usual replacement the 1N4148? I am going to replace the diodes on this board but would like to hear your reasoning for that particular replacement. Thanks!Protection board up next...
Protection Assembly (AWH-062-0)
Capacitors:
C1 / 0.22 uF 10v Electro (CSSA) / 0.22 uF 100v MKS2D032201C00KI00
C2 / 0.22 uF 10v Electro (CSSA) / 0.22 uF 100v MKS2D032201C00KI00
C3 / 330 uF 6.3v Electro (CEA) / 330 uF 16v UPW1C331MPD
C4 / 330 uF 6.3v Electro (CEA) / 330 uF 16v UPW1C331MPD
C5 / 4.7 uF 25v Electro (CEA) / 4.7 uF 63v MKS2C044701M00JO00
C6 / 100 uF 16v Electro (CEA) / 100 uF 25v UPW1E101MED
Transistors:
Q1 / 2SC869 / KSC1845
Q2 / 2SC869 / KSC1845
Q3 / 2SC945 / KSC1845
Q4 / 2SC945 / KSC1845
Q5 / 2SA733 / KSA922FBU
Q6 / 2SC945 / KSC2383YTA
Q7 / 2SC1384 / KSC2690AYS
Diodes
D1 / 1S2472 1N4148
D2 / 1S2472 1N4148
D3 / 1S2472 1N4148
D4 / 1S2472 1N4148
D5 / 1S2472 / 1N4148
D7 / 1S2473 / 1N4148
D8 / 1S2473 / 1N4004
+ 1N4004 fly-back diode is added between pins 9 (anode +) and 10 (cathode -)
Before:
After:
