Project: Realistic STA-2000 (Rebuild)
Super Noob
Here is the most recent patient:
This was my 2nd acquisition of vintage gear about 4 years ago. Rat shack 2nd best has been doing service in my daughter room over the last couple of years. It is partnered with pair of HPM 60s (great combo). It sounded good, but I wanted to do some preventative maintenance for longevity's sake - as well as get the indicator lights working.
Here is the verified list of components:
https://drive.google.com/open?id=1XaYHBnEAlE1OAIyAqXKU9yoe44LCRrVr
Here comes the posts.
:blah:
While caps were on order... I troubleshot the indicator lights down to the power supply board. Foster sure used a ton of glue on this board = replaced a diode, and let there be light. Since I have LEDs on hand = re-lamped all incandescent bulbs. Fuse style, T-10s, and 5 mm LEDs.
_dVC-FA4fcbIfkXDdVKhgHYbZlaFBXoAsrUK9wsHno7iH3XB65UcGJ8nhJYtn6RCtK_dtPNt57Msr0Xw6FFOUJBYLGARmTXg8EEO=w165-h220
Next = Power Supply Board (half my time on this entire project was pulling glue).
Did not get a picture of the before...
After:
qPH_n5GCgKgT63oWPyVQ5KRqDI23jOIYZ0Yqjy7HAvCZAaVukHN8g40oLDMvMTZczDsdjC_oOigJNQL97_P-UBJ2UUdjp9lk424L=w165-h220
Parts:
7pF5FKSCUlN-D8Jaqr40EJ1vJeD6-kznOtHLJuQgJsGZXCNWghLX2WPnF5k-sne4i_snlzbQEZwZBPlvOc508iF0CwhvXUy5x7m4=w293-h220
Nice!
I had one of these once, I wished I'd kept it and restored it.
Lee.
Main Amp Next:
First Re-Paste The Main Output Transistors:
Before (note you can do all the work on the boards and outputs without undoing the wired post on the board). The rivets on boards flanges (to the heat sink) were a bit of a challenge to pull, but I had much luck in getting them out.
2KtLyk9DxkuFKzULFLJzX-Ceb0VFI-T51NKeWMjoIg2hoZnzp_ePHf2Zsp3O2mMEQFRrwLE3bYKavZAW4VskDAJ_3TB9tgjRKlEj=w165-h220
TVSSAc_OeeJpnIeLpavLfyJIw26v2NUA2qak4VsfgSkaiLnGquffJawmN0hU7QbsOfFSrpdH56qyTOSyOjyvDXRG-7T_j3MwN0T_=w165-h220
MBjJErcPz7dYt-rmJd58Ire9SUpSYIHJWhRKu2FcNIbZAovC8UYGXB9mmlgX6BAMrAbMR9AFuTq_e8huIAFRvh-z4ccjPWgImusm=w165-h220
yyZ_KNGbNzFHXcKINhW7uoIXDDo2rtnVIjfAH-1xONfO8CHnDa_i86L7-LpYqNkwFyafJVRVtWxe2cm_uqNweJ9AIwviNK0SYh6y=w165-h220
Main Amp Boards. Note that I did replace the double diodes and adjustment trim / variable resistors.
Before:
E0dXhGke4auVa-mJNKsZjrG_pNfo74CLq6ipvLqgsuhfbQ0gmmTvLT8iEPMyYMoy3YF_5yQJbVK7JAJ2K3ZgctK9Ls3Perfp55Yi=w293-h220
After:
5LcTRtREgEaoPtI27pP63TjYzRkuq5sTvl17akv4VfjR4rcbyJ7jKP857vXWETkShTHRtfVB-mIg_1pDvp9SU2euCshMipC2v1q-=w293-h220
Parts:
2En63G032WSIZh4xnRJ3IqPiJpbkhgDFD41lUDVR1YICXdwDAKt6jfeJXuQjtgAn5WmEO1zyQ9K3KRGWf-D7vabYdBJlUD5OPVof=w165-h220
Up Last = Main Filter Caps
(note I have been adding 2.2 uF bypass caps on my rebuilds per recommendation of others= MTF)
Check out how I changed these... very happy with how easy this was.
ikPXzyFHf7RRC6_IaWQZyrFtw8ui3J6M710CBNpcVi9uyFY10XlZj_UlCaixGUctdJ_wYP5srNIq2vNyXzJ3OtAFiXUkn3orNaNi=w293-h220
QO0df2kaZvU0CtLxT0t6WkXO9QtXQ272ArvhlrWxhplo_tYW4HqoA5D0jvm9Z23HGxAGxNhoGWZR3NSnzI6FMiSg6EiCQqTGP3BD=w293-h220
offrjQQwmuvJjkjK667MM-jMih3nknmEst_4CpLuH4N8vpUHCjm93cb-D_zvrMTow3cTyXuLJb8RC-7q3BAq3F-xlRhDwTidMU9o=w293-h220
yPyPPsSzQVbRFabrCbf08NaV2Vq_MPKefE4noJc55ATSMOxfsiyEpTB86MGpvJ43vsTiYs9M_IR556_1jpn5do5Coknwnc6ckHtz=w293-h220
wVKUuLua-5yJ4wd4zLgIH9x68k3LBWZ1xvTomS11BT_0WZua-EHKWF-PjF1PzUfGjI8dF8D-ZQm5g2Dtuz8Helaa8irQcplcrC47=w165-h220
6jaVlLOPp06-Wm1GHA5SlRs6kJWnAAjM3RjLg391yvU5daZP8XW87aEsb6LmHS7JX8goXANkk-EU3BW9X-nqT5nm0S4rJuliBPuY=w293-h220
Excellent post! I have a D version awaiting similar rebuild. Have been putting it off but the receiver needs the TLC. May hit you p with a few Q's as I get into it.
Thanks for the post!
Dave
Awesome rebuild!
Though admittedly I like the incandescent over the LEDs.
Mine definitely needs a recap such as this but heck I just got it working again
Hope you did the FM Muting board, mine failed there.
Thanks for sharing, jealous of your skills!
Ben
Awesome job! Step by step instructions! Thank you! I've got a 2100d that I've been wanting to get up and running for a year now but it alittle out of my expertise. I'm a big fan of Realistic so I'm glad to see you keeping this unit running strong for many more years to come! :thumbsup:
Very nice write up. Sound like it was worth doing. Since it now sounds great. Another 20-30 years out of it.
I have a STA-2000 that needs a volume potentiometer. It is a four gang, single shaft 200K ohm. I can't find one anywhere. Suggestions?
