Super Noob
As the saga continues, I had an opportunity to pick up a couple of vintage Pioneers locally. As you know my flavor is Pioneer, and here is what landed in the garage.
A euro 737 and SA-8800. The 7730 had two noticeable issues.... glass was replaced with Lexan & tuning needle was not moving. I really enjoy early 70s pioneers including the early direct coupled units. I have a 1010 and have built a 727 for a friend. These early units never disappoint.
7730 or 737
Power output: 35 watts per channel into 8Ω (stereo)
Frequency response: 15Hz to 40kHz
Total harmonic distortion: 0.5%
Damping factor: 40
The following posts will highlight my build in the hopes that you will enjoy the journey and maybe be inspired to revive this rig if it ends up at your stable. Pretty much have solid stock of parts here... UKL, UPW, UKA, and films. It should be noted that many of the parts are likely on back-order; however, if you look hard enough I am sure you find some acceptable alternates. Many have documented builds of the 737, and there are good foundation lists floating around from the likes of MTF and Larry'D.
Let's Begin
7730 or 737
Damping factor: 40
Let's Begin
